Will not start
1,700,000 MILES
CHRISTINA CALLANS
  • 5 POSTS
New starter,new solenoid battery good fuses good. still won't start.
Aug 14, 2020 at 12:10 PM
  • 110,248 POSTS
I would be happy to help, but I need more information. First, does the starter engage and turn the engine? Second, is this a 5.4L V8 or the 4.6L V8?
If the starter isn't engaging, did you check the starter relay? Have you checked to see if there is power to the starter? I ask because there is a fusible link between the battery and starter relay that may have failed.
Take a look through this link and let me know if anything helps. It deals with the starter motor not working. If that isn't what is happening, let me know.
Also, I attached a pic of the wiring schematic for you to see.
Aug 14, 2020 at 1:58 PM
CHRISTINA CALLANS
  • 5 POSTS
Put in new starter and starter solenoid, checked fuses,battery is good. Sounds like it wants to start.Tried to start in neutral didn't start.My dashboard goes on but gas not working, also put a new selector wire in too.I have a full tank of gas dashboard not registering it.
Aug 19, 2020 at 4:02 AM (Merged)
Good morning,
Does the engine crank when you turn the key to start?
Do you have a voltmeter to test the battery voltage?
CHRISTINA CALLANS
  • 5 POSTS
Please help me.
I am trying but you must give me information to help you.
Please read my previous post and answer my requests so I can help.
CHRISTINA CALLANS
  • 5 POSTS
I put a new starter in a new solenoid in checked fuses battery is good.My truck still won't start.Sounds like it wants to start. Don't want to put in shop don't really have the cash to do so.
  • 110,248 POSTS
Is the starter engaging and turning the engine, but it just won't start? Let me know. Until I hear back from you, here is a link you may find of interest. It discusses the most common causes of a crank no start condition.
CHRISTINA CALLANS
  • 5 POSTS
If the battery terminals need to be replaced would the truck even turn over?
  • 110,248 POSTS
That really would matter how bad the cable or terminal is. Can you take a picture of what it looks like so I can see it? Also, explain what is happening.
Aug 19, 2020 at 4:03 AM (Merged)
