It wont start or fire. we changed the computer. pick up coil. fuel pump relay. ignition coil and still wont start or fire.
Feb 8, 2019 at 3:52 AM
SCGRANTURISMO
✓Experienced Mechanic
This sounds like it could be a problem with your Crankshaft Position Sensor(CKP). Here are are a few links explaining what a CKP sensor is, symptoms of when it goes bad, and how to replace it:
Also, I have included a factory Inspection flow chart for you in the diagrams down below. Check it out and let us know what you find out.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Feb 8, 2019 at 11:35 AM
If I can jump I here. Will it run on starting fluid? Next if you turn the key on while cranking the engine can your hear the fuel pump run for five seconds?
