drive down the freeway and the engine just cuts off?
126,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JESSICA GIESSEN
Well, I was drive down the freeway and the engine just cuts off. And the vehicle hasn't started since. I replaced the fuel relay switch, I've also checked the fuel filter it's clean the pump is working now that the relay is new. I've also checked for spark, fuel and compression. That's all good.so I am stumped as to what it could be. I don't want to put more money into this car if I don't have to. Please help!!
Jun 16, 2021 at 1:29 AM
If this is a crank no start then we need to run through this guide and see what turns up:
https://youtu.be/dCjmRL3p4Cs
However, I think we need to clarify how you confirmed there is no fuel or spark. The engine just needs fuel, spark, and compression to run so I am thinking we are missing something.
Have you checked the fuel pressure?
Let me know what the pressure is and then how you checked for spark. Did you pull a spark plug and then crank the engine?
Let's start with this info and go from there. Thanks
Jun 17, 2021 at 11:20 AM
JESSICA GIESSEN
The vehicle is getting fuel, spark, and compression. Yes it will crank but no start.
Jun 18, 2021 at 3:00 AM
Okay. More than likely we are missing something because if you have all three, it should be starting.
So are you checking the fuel pressure? If so, what is the PSI when cranking the engine?
Also, what are the compression readings you are getting?
Then how are you checking spark? We need to pull a plug and make sure it is getting all the way to the plug.
What do the spark plugs look like? Are they fouled?
Jun 19, 2021 at 12:13 PM
