Will not start
140,000 MILES • 3.4L
MIKEGUTIERREZ5532
Turn key to start nothing happens no power . Turn key to access. Power comes on . Battery is one year old terminals are clean and tight. Alternator is outing out at 13.v. This happens approximately 2-3 times a week. After cont.trying it starts?
Jun 28, 2021 at 12:43 AM
Good afternoon,
This sounds like the starter has a dad spot. Each time it lands on the spot it will not start until it is moved around.
I attached a wiring diagram for you to view. Test the little wire on the solenoid for power when it does not start.
I also included the procedure for replacing the starter.
Jun 28, 2021 at 2:39 AM
MIKEGUTIERREZ5532
Thank you will try it . Thanks for wire diagram.
Jun 28, 2021 at 3:56 AM
You are welcome.
Always glad to help.
Jun 28, 2021 at 4:40 AM
