It started this morning and afternoon then went to the bank and now it wont start. the battery is fine. what could be the problem?
Feb 7, 2019 at 11:58 AM
SCGRANTURISMO
✓Experienced Mechanic
There are a couple of things that would cause this to happen. It could be a bad crankshaft sensor, bad fuel pump, or fuel pump relay. The good news is that I am giving you a link to a guide that will help you pin down the exact cause of your no start condition. Go through this guide and let us know what you find out. If you need more help or have a different question we will be glad to help. Hope this helps.
