Welcome to 2CarPros.
Does anything electrical work? If not, have you checked the battery for charge? Also, have you confirmed that the battery terminals are clean and tight?
I realize those are basic questions, but I'm not sure what has been done so far. Here are a few links you may find helpful:
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-to-charge-your-car-battery
If possible, I need you to check two different fuses. See pics 1 and 2. Pic 2 shows fuse panel C which is on the left side of the dash. Pic 1 is located in the left front of the engine compartment.
Also, I need to know what engine it has and if it is an automatic or manual transmission.
I have no idea your abilities, but here are a few more links that you may find helpful when checking for power at the fuse and the fuse itself.
Images (Click to enlarge)
Jun 26, 2019 at 1:21 PM
