Will no start
130,000 MILES • V6 • AUTOMATIC
MINDICOSBY
My car has a push start. It will continuously crank but never start. It is not throwing any bad codes when hooked to scanner, fuel pump is good, has gas. What could be wrong?
Aug 8, 2018 at 3:44 AM
  • 110,248 POSTS
If you checked and the fuel pressure and system is working correctly, then I would suspect an a problem with ignition spark. Interestingly, the crankshaft position sensor can be faulty and not set a code. If it is not working, you will not get spark and the engine will not start. Take a look at these links. They discuss symptoms and how to check and replace the component.
If you find the sensor is the issue, here are directions specific to your vehicle to replace it.
_______________________________________________
CRANKSHAFT POSITION (CKP) SENSOR REPLACEMENT
REMOVAL PROCEDURE
- Turn the ignition OFF.
- Raise and support the vehicle. Refer to Vehicle Lifting.
- Reposition the wiring harness heat shield to obtain access.
- Disconnect the crankshaft position (CKP) electrical connector (3).
- Remove the crankshaft sensor bolt.
- Remove the crankshaft sensor.
INSTALLATION PROCEDURE
- Install the crankshaft position sensor.
- Install the crankshaft position sensor bolt.
NOTE Refer to Fastener Notice in Service Precautions.
Tighten the crankshaft position sensor bolt to 10 N.m (89 lb in).
- Connect the CKP electrical connector (3).
- Install the wiring harness heat shield to the oil level indicator tube.
- Lower the vehicle.
The attached pictures correlate with the aforementioned directions.
I hope this is helpful. Let me know if you have other questions or need help.
Aug 8, 2018 at 12:30 PM
