No start
225,000 MILES • 7.3L • V8 • MANUAL
TOM006
I just drove this truck the other day. I went to start it the other day and the batteries were really low. 24 hr trickle charge and they are strong again. still will not start. I changed out the camshaft position sensor. ( do know that this goes it will not start) it still will not start. I am not sure where to look next
Aug 31, 2017 at 8:24 AM
STEVE W.
  • 15,418 POSTS
So it turns over okay but will not start? I would start on the fuel side and make sure you have fuel up to the injector pump. Is there white smoke coming out of the exhaust as you crank it? Check the oil level in the high pressure pump. Check the glow plug relay and fusible link.
When you last drove it was it running okay?
Sep 1, 2017 at 3:30 PM
