i replaced the starter. the car started then i turned it off. went to start it again but it just turned over. checked the fuses, found a blown fuse [15 amp] to the ecu. replaced with a 30 amp fuse. the engine started but i noticed smoke coming from around the starter area, turned off the engine. checked the starter and found that the battery cable was grounding to the heat sheild. fixed that. checked the fuse to the ecu and it was NOT blown. turned the engine over and will not start. i changed the 30 amp fuse back to a 15 amp fuse. checked all other fuses and they are good. engine turns over but will not start
Jul 15, 2016 at 10:14 PM
