I crank the SUV up, it starts then immediately cuts off. I have changed the fuel filter and added gas and still will not crank, What do I do now?
May 23, 2019 at 12:28 AM
✓Experienced Mechanic
Welcome to 2CarPros.
If it starts then shuts off, have you checked to see if the fuel pressure is within the manufacturer's specs? Also, have you checked to see if spark is lost to the spark plugs?
I am going to provide two different links. One explains how to check fuel pressure and the other spark.
