Engine shut off while running now will not start
221,853 MILES • 2.9L • 6 CYL • AUTOMATIC
JENNIFER BALDWIN
Outside of losing a little water is running fine went to store while doing errands came out it started but was idling rough shut off and have not been able to start it since. I am being told it is fuel pump. Can I check for sure?
Dec 5, 2018 at 3:24 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny,
If you want to perform a fuel pressure test the specification for your car should be 43.5 PSI. If you do not have access to a tester your local auto parts stores have a tool loaner program and will rent you one. I have attached a tutorial showing what is involved. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 5, 2018 at 5:04 AM
  • 55,721 POSTS
When you turn the key on without cranking the engine over can you hear the fuel pump running?
This guide will help.
Cheers, Ken
Dec 6, 2018 at 2:21 AM
