Will not start
21,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
BISMARK477
Been sitting for ten years just 21,000 miles like new. turns over but will not start.
Jan 3, 2018 at 2:18 AM
good afternoon.
The first thing you need to do is drop the full tank, remove all the fuel have the tank flushed and replace the fuel pump.
clean out the line to the injectors and hopefully it will not need injectors.
change the fuel filter as well.
change all fluids before running as well. they have all separated and can no longer perform there job
I would start there.
Jan 3, 2018 at 4:48 AM
BISMARK477
I will do and let you know. thanks a lot.
Jan 3, 2018 at 7:48 AM
You are welcome.
Jan 3, 2018 at 8:39 AM
