Will not spray gas into the throttle
245,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARTINMARIE
Will not crank unless you spray fuel in the throttle then it will crank.
Mar 12, 2018 at 7:39 PM
Good morning.
The first thing I would do is check the actual fuel pressure. there is an access port on the fuel rail. you can rent one at a parts store to verify.
Also, check all the fuses with a test light for power on both sides.
Mar 12, 2018 at 7:55 PM
