Will not crank unless you spray fuel in the throttle then it will crank.
Mar 13, 2018 at 2:39 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Good morning.
The first thing I would do is check the actual fuel pressure. there is an access port on the fuel rail. you can rent one at a parts store to verify.
Also, check all the fuses with a test light for power on both sides.
