Will not shift out of park
250,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RICKE2
Started car. Could not shift out of park.
Shifter does move. But no movement of gear selector.
Mar 10, 2018 at 9:22 AM
  • 55,628 POSTS
Just had this problem it was the brake light switch do the brake lights work?
Here are diagrams (below) to show you what you are in for to fix the problem also check the fuses to make sure they are good.
Check out the diagrams (below).
Cheers, Ken
Mar 12, 2018 at 5:17 AM
