Reverse, park neutral and first gear all work, but car will not shift out of first gear into second or third or fourth.
Aug 21, 2018 at 8:03 AM
✓Experienced Mechanic
It sounds like you have a turbine sensor that has gone out which will cause the issue. Here is a video of one getting replaced on a different car but the same procedure:
