wont run unless at idle
1993 FORD PROBE
175,000 MILES
RDCOUNTRY6
I have a 93 ford probe gt. It will run fine as long as it is
At idle. When I give it some gas it spits and pops and will
Cut off. It takes a couple of tunes to get started again.
I just replaced distributor and crank sensor. Doe anyone have any ideas on what it could be?
Apr 19, 2013 at 7:16 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first the fp may be low need to know engine size for specs.
Apr 19, 2013 at 8:13 AM
