will not run smoothly
180,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JOHNNY COLLINS
Truck stopped running while driving down the road, towed it home. put a complete tune up on it still idle bad a buddy came over and scanned it he said that the crankshaft sensor was bad.I replaced it still will not idle smoothly. Why?
May 15, 2017 at 6:29 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner. this may be an injector problem as GM changed a lot of them due to poor running qualities. also check for a vacuum leak. like hoses. o-ring leaks around plenum and scan for codes.
May 15, 2017 at 8:48 AM
  • 55,682 POSTS
If the rough idle seems to be consistent then I would do a compression test to see if you have one low cylinder.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 18, 2017 at 3:56 AM
