Code p0122 will not run in drive?
202,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
RONG7088
It is giving a p0122 code. I replaced the MAP sensor, and it still has the code. Where do I check now? it revs up a little and back to idle and eventually shuts off. I thought I overheated it. I pulled the head. replace timing belt, water pump, plugs, wires cap and rotor. Had the checked and resurfaced.
Mar 23, 2023 at 8:57 PM
  • 55,721 POSTS
P0122 Throttle Pedal Position Sensor/Switch (TPS) A Circuit Low Input. so I would replace the TP sensor which is location on the side of the throttle body. Here is the location in the images below. Please let us know what happens.
Mar 24, 2023 at 12:05 PM
