Will not stay running
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MALISTERA
Starter burned up so I replaced. Car started and ran for two seconds, and now it won't run at all. New starter works though. It's like the fuel pump isn't turning on. What would cause this and where's the fix?
Jul 15, 2021 at 11:53 PM
SQM
  • 6,383 POSTS
Have had the car scanned for codes? That might help point you to the right direction.
https://youtu.be/dPOrNy-Y9Ng
This not starting can be for lack or fuel or lack of spark.
Check to see if you are getting fuel. The ideal pressure should be 50-60 PSI with key on, engine off.
This is a helpful article on how to check for fuel issues:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
You might want to check to see if you are getting spark to the plugs.
https://www.2carpros.com/articles/how-to-change-spark-plugs
I have attached fuel system diagnosis and pump replacement procedure.
Jul 16, 2021 at 12:29 AM
