No crank no start issue?
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
TC CHILDRESS
Won't start or run unless I spray gas directly into engine start and shuts off.
Aug 21, 2022 at 2:17 PM
  • 110,248 POSTS
Based on your description, either you have a faulty fuel pump, or you have lost an injection pulse.
Can you hear the fuel pump actuate for a couple of seconds when you first turn the key on? If you can, test fuel pressure. If we have pressure, then the injectors don't get a pulse. If there is no pressure, check fuses and relays. If they are good, the pump is likely bad.,
Here is a link that explains how to test fuel pressure:
Do this and let me know the results. Also, let me know if you have other questions or if I can help in any way.
Aug 21, 2022 at 2:35 PM
