Crank no start issue
150,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
BIGGS
  • 16 POSTS
Will not run, it turns over but will not start. she says it is the oil sending unit, but what do you think is this possible?
Jan 11, 2018 at 2:49 PM
CARADIODOC
  • 34,414 POSTS
Nope. Have you checked for spark and fuel pressure?
Jan 12, 2018 at 10:41 AM
BIGGS
  • 16 POSTS
have not got to look at it yet, but did not think that would affect it, thank you.
Jan 12, 2018 at 11:01 AM
CARADIODOC
  • 34,414 POSTS
Check for spark, and try to listen for the hum of the fuel pump. That hum will only last for one second when you turn on the ignition switch.
Jan 12, 2018 at 11:30 AM
