Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Fuel System
Fuel Pump
After replacing the fuel pump and tank the engine will not stay running?
1984 CHEVROLET S-10
100,000 MILES • 4 CYL • 2WD • MANUAL
BOBLAMO1111
MEMBER
1 POST
i just replaced my fuel pump and tank i start it and it doesn't run long.
Mar 6, 2025 at 2:58 AM
Experienced Mechanic
Did you use an OEM pump? I have seen aftermarket pumps not work correctly. Can I ask if the engine ran before the pump replacement?
Mar 7, 2025 at 2:34 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
