will not restart
130,000 MILES • 2.7L • 6 CYL • FWD • AUTOMATIC
MARYSANTI
After running for while if i turn car off it will restart if i start it right away if it is off for awhile it will not restart for about another thirty minutes. Mary
Aug 9, 2017 at 4:05 AM
CARADIODOC
  • 34,414 POSTS
This is the classic symptom of a failing crankshaft position sensor or camshaft position sensor. They often fail by becoming heat-sensitive, then they work again after cooling down for an hour or so. While driving, natural air flow keeps them cool. When a hot engine is stopped, the engine heat migrates up to those sensors and causes them to fail. That is called "hot soak". That usually occurs when stopping for gas, but in your case the sensors might not get hot enough to fail that quickly.
Aug 9, 2017 at 4:57 AM
