Will not pick up speed and seems to bog down at stops
2005 DODGE NEON
95,874 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ALVINRAGSDALE99
New transmission and it still will not pick up speed and go. Don’t know where to start.
Oct 11, 2019 at 6:22 PM
  • 110,244 POSTS
Welcome to 2CarPros.
This type of issue can be the result of a few things. However, anytime there is power loss, my first suspect is a plugged catalytic converter. Take a look through these links and see if they help:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Try the test and let me know what you find.
Oct 12, 2019 at 3:11 PM
ALVINRAGSDALE99
Thank you for replying. Yes, we unhooked the catalytic converter and it’s still not picking up speed. It also has one code p0562. I also replaced the battery as a well.
Oct 13, 2019 at 10:20 AM
  • 110,244 POSTS
Welcome back:
Interestingly, that code is relevant for both engine and transmission. As far as the transmission, if the battery voltage of the Transmission Control Relay Output Sense circuit(s) to the PCM is less than 10.0 volts for the period of 15 seconds a P0562 is set. Generally speaking, it indicates a gradually falling battery voltage or a resistive connection(s) to the PCM. Here is a list of thing that could be at fault. These are right from the manual.
POSSIBLE CAUSES
- RELATED CHARGING SYSTEM DTC'S
- GROUND CIRCUIT OPEN OR HIGH RESISTANCE
- FUSED B+ CIRCUIT TO RELAY HIGH RESISTANCE
- FUSED B+ CIRCUIT TO PCM HIGH RESISTANCE
- TRANSMISSION CONTROL RELAY OUTPUT TO TCM OPEN OR HIGH RESISTANCE
- POWERTRAIN CONTROL MODULE
- INTERMITTENT WIRING AND CONNECTORS
________________________________________
As far as it being an engine code, it ties directly in with the idea that the battery voltage is low. I realize you replaced the battery, but many other things can be the cause. There could be excessive resistance between the alternator and the battery allowing voltage to drop as well as a ground or connection issue.
Do me a favor. We will start at the simple end of things. Lets confirm that the battery is being properly recharged when the engine is running. Even a new battery can fail if the alt isn't doing its job.
It's really simple to test. Follow this link. All you really need is a volt meter. Additionally, reconfirm the battery cables are tight and clean and the ground between the battery negative and both the body and engine block are clean and tight.
Do this and let me know the results.
Oct 13, 2019 at 12:50 PM
