Code p1381, will not pass emissions smog test?
193,225 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
NICKERSON.J
The code p1381 comes up cylinder position sensor. High on Hc (PPM) NO (PPM).
Feb 25, 2023 at 5:46 AM
  • 110,248 POSTS
The code indicates there is either a wiring issue to the sensor or the sensor itself has failed.
Do me a favor. I attached the diagnostics below specific to this code. Take a look through them and let me know if you are comfortable performing them.
Feb 25, 2023 at 3:22 PM
NICKERSON.J
Yes, thanks.
Feb 25, 2023 at 8:56 PM
  • 110,248 POSTS
You are very welcome. If you have a chance, let me know what you find. I'm interested in knowing.
Feb 26, 2023 at 11:56 AM
