Won't move water through
240,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MATTHEW MARCUM
  • 42 POSTS
It won't move any water through the block what Could it be
Jan 27, 2019 at 8:28 AM
Good evening
2 things come to mind.
1. Water pump. If the water pump is not moving water through the system, this would cause your issue. The impeller not working could be the cause.
https://www.2carpros.com/articles/water-pump-replacement
2. Thermostat. If the thermostat is stuck closed, it will also give a no circulation issue.
Jan 27, 2019 at 10:02 AM
MATTHEW MARCUM
  • 42 POSTS
Thanks
Jan 27, 2019 at 4:42 PM
Your welcome
Always glad to help
Jan 27, 2019 at 6:27 PM
