Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Engine Cooling
Won't move water through
1998 CHEVROLET CAVALIER
240,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MATTHEW MARCUM
MEMBER
It won't move any water through the block what Could it be
Jan 27, 2019 at 8:28 AM
Experienced Mechanic
Good evening
2 things come to mind.
1. Water pump. If the water pump is not moving water through the system, this would cause your issue. The impeller not working could be the cause.
https://www.2carpros.com/articles/water-pump-replacement
2. Thermostat. If the thermostat is stuck closed, it will also give a no circulation issue.
Jan 27, 2019 at 10:02 AM
MATTHEW MARCUM
MEMBER
Thanks
Jan 27, 2019 at 4:42 PM
Your welcome
Always glad to help
Jan 27, 2019 at 6:27 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
