Makes no noise when in park idling but shifting in reverse or drive has a bad noisy clanky grinding sound with vibration and won't move.
Dec 13, 2022 at 11:27 AM
✓Experienced Mechanic
It sounds like the rear end is having a problem, but to be sure have a helper put the truck in drive or reverse while you look under the truck using a flashlight to see if the driveshaft is spinning without the truck moving, this will confirm the problem. Let us know what happens and please upload pictures or videos of the problem.
