Will not move with the drive shaft removed?
178,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
RDAYW79
I pulled the front drive shaft off went to take off ramps but it won't move.
Jun 5, 2021 at 11:15 AM
Good afternoon,
If you have quadra trac it is in 4 wheels all the time. When you remove the driveshaft, it will not move as it needs to be there.
Check and see if you have a switch on the dash for 2 wheel drive. If not, then it is all wheel drive all the time.
Jun 6, 2021 at 4:54 AM
