Engine will not idle on its own?
135,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
HOLY LOBSTER
My vehicle has good compression on all 6 cylinders. However, the three passenger side cylinders have no sign of combustion. Replaced fuel filters as well as rails and injectors. IAC valve. TPS, MAF, I'm replacing crankshaft position sensor tomorrow. Help, I'm stumped.
Jan 8, 2025 at 11:31 AM
  • 55,604 POSTS
Are the fuel injectors getting a trigger signal from the ECM? Also, with the key on there should be 12 volts at one of the wires to each of the injectors, they use a ground to close the circuit form the PCM.
Here is a guide that can help you test what I am talking about:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please go over this guide and get back to us.
Jan 9, 2025 at 3:39 AM
