Code p061c, engine does not idle?
200,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SBRACKENS
  • 26 POSTS
Code p061c
Just had throttle body installed, because poor acceleration, stalling below 10 MPH.
And below 1 RPM.
Wrench light was on
Was told throttle body,
Did that
Now wrench light off but will not idle.
Drives fine.
Tried a few things said online like turn the key on do pedal etc.
Another said foot on break, turn the key on, put gear in d let idle.
Can't won't idle.
Another disconnect positive terminal,key on access, clean terminals, tap 3 times, connect start,
All do nothing,
Was told throttle may be defective
So, took out replaced (got from O'Riley's)
All above same result
1 code
P061c
May 24, 2023 at 3:29 AM
  • 55,743 POSTS
I would check for a vacuum leak, or you got a defective throttle body, please check out these guides and get back to us.
https://www.2carpros.com/articles/stall-at-idle
And use this guide when the engine is cold only:
The error code P061C in a 2011 Ford Focus indicates a problem with the internal control module torque calculation performance.
I would clear the codes to see what happens. Please go over these guides and get back to us.
May 25, 2023 at 2:18 AM
SBRACKENS
  • 26 POSTS
Exchanged throttle body.
Still same, all the above.
Also forgot or say cold A/C come out left side vents and heat come out eight side when A/C on.
So now going to do tour other suggestions above, okay.
Thank you very much!
I will return.
Looking for vacuum leaks now.
Ty
May 26, 2023 at 3:56 AM
SBRACKENS
  • 26 POSTS
Mentioned heat comes out of right vents.
May 26, 2023 at 3:57 AM
SBRACKENS
  • 26 POSTS
Okay, no vacuum leaks.
Still same, and now no5 getting any codes.
Still no idle, start fine, no idle, got to keep foot on gas pedal.
May 26, 2023 at 6:10 AM
  • 110,248 POSTS
I noticed we haven't been in touch for a couple of days. Have you been able to make any progress? We are interested in knowing.
Let us know,
May 28, 2023 at 12:43 PM
SBRACKENS
  • 26 POSTS
I did reply.
No vacuum leaks found, still same.
What else should I try?
Thank you
May 28, 2023 at 11:03 PM
  • 55,743 POSTS
I have seen the EGR valve stick open and cause an internal vacuum leak. Here is a video to show you how to test it and the location of the valve in the images below so you can remove it for testing:
https://youtu.be/DqUCbbKdWf4
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 2:25 AM
SBRACKENS
  • 26 POSTS
Thank you, I appreciate your responses, will be trying the above hopefully tonight or tomorrow, ASAP. I will be back, again thank you.
May 30, 2023 at 6:56 AM
  • 110,248 POSTS
You are very welcome. If you have a chance, let me know the outcome. I'm interested in knowing the results.
Take care and let me know if I can help in any way.
May 31, 2023 at 11:49 AM
SBRACKENS
  • 26 POSTS
HI, my helper with car is over working on my car.
It breaks down just about every 6 weeks since I've had.
So, I'm taking it to the mechanic on Friday.
I do appreciate all your help.
Y'all are my go to every time.
So, I should be able to get with you Saturday and let you know what the problem is, okay.
Thank you
May 31, 2023 at 11:58 AM
  • 110,248 POSTS
Absolutely. Feel free to come back any time. I'm always here.
May 31, 2023 at 2:54 PM
SBRACKENS
  • 26 POSTS
Car fixed!! it was crankshaft and cam position sensors!!!
Thank you again!!
Jun 2, 2023 at 4:09 PM
  • 110,248 POSTS
Thank you for the update. I'm glad to know it has been repaired. Also, your post will likely help others in the future.
Take care and feel free to come back anytime in the future.
Jun 3, 2023 at 2:18 PM
