Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Vue
Engine
Symptoms
Stall at Idle
Will not idle, shuts off when RPMs are below 2,000?
2005 SATURN VUE
125,000 MILES • 2.2L • 4 CYL
RNMONARK
MEMBER
1 POST
Throttle body no learn idle. Shuts off if idled below 2000 rpm?
Aug 18, 2022 at 1:53 AM
Experienced Mechanic
Are there any trouble codes? You can get a code scanner from Amazon for about $20.00.
Here is a guide/video to show you how:
Here is a scanner link:
https://amzn.to/3Qi1SS6
Also, if you can shoot a quick video of what the engine is doing it will help us fix it, you can upload it here in your response. This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Does the engine make a strange noise at all? Please run down these guides and report back.
Aug 18, 2022 at 5:03 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
