Engine will not idle
100,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
PACIFICISLANDER
  • 239 POSTS
Trying to find out which wire is hot, white or black on wire on the fuel cutoff solenoid.
Apr 7, 2021 at 3:07 PM
  • 110,248 POSTS
Because of the model year, my schematics are very limited. The only thing I found was in black and white and doesn't indicate wire color.
What I did is this. If you look below, I attached two basic schematics for the fuel cutoff solenoid. Look at the orientation of the plug to determine which wire goes to ground.
Let me know if that helps. Also, here is a link you may find helpful:
Apr 9, 2021 at 12:48 PM
PACIFICISLANDER
  • 239 POSTS
Okay Joe, got it figure out the white is the hot manuka, you're good reminds of somebody. Thank you for the help much appreciated. take care be safe.
there's no plug.
Apr 9, 2021 at 2:05 PM
  • 110,248 POSTS
You are very welcome. Please feel free to come back anytime in the future. Also, if there was no plug, how did you figure it out?
Apr 9, 2021 at 3:45 PM
PACIFICISLANDER
  • 239 POSTS
The wires are cut, all of it what. I did I join all the wires together run it to the ignition circuit' then ground it.
i took out the fuel cutoff solenoid then watch it when i connect it to the battery, that's how i did it.
thanks, be seeing you again. have a great day my friend.
Apr 9, 2021 at 7:24 PM
PACIFICISLANDER
  • 239 POSTS
forgot sorry the hot is black wire on fuel cutoff solenoid.
Apr 11, 2021 at 5:55 PM
  • 110,248 POSTS
Thanks for the update. The only concern is in the event of an accident, the fuel pump won't turn off until the key is off. That could be dangerous.
Regardless, take care of yourself.
Apr 12, 2021 at 11:37 AM
PACIFICISLANDER
  • 239 POSTS
No it's not kind of inertia switch it's just the FCS and other circuit its not tied in with the fuel pump.
Apr 13, 2021 at 6:39 AM
  • 110,248 POSTS
Okay. Thanks for the update.
Take care of yourself and let us know if you have questions in the future.
Apr 13, 2021 at 11:30 AM
