Will not hold Antifreeze?
205,000 MILES • 2WD • AUTOMATIC
AMY84MARIE
The overflow tank is full but when I attempt to add antifreeze to the radiator it runs straight out on the ground.
Dec 13, 2022 at 6:26 AM
  • 110,248 POSTS
Either we have a failed radiator hose or the radiator itself has a hole in it. Are you able to see approximately where the leak is coming from? Could you take a few pics so I can see where it could be leaking from?
Check to make sure it isn't the lower radiator hose. Also, here is a link you may find helpful:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know what I can do to help.
Dec 13, 2022 at 2:39 PM
