Will not hold an idle
211,000 MILES • 2.4L • 4 CYL • 2WD
WILLIEDYNAMITE11
  • 37 POSTS
When I bring the car to a stop it won't idle unless I give it gas continuously. will run after that once I get it up to speed. what do you think that could possibly be? please and thank you. let me know.
Dec 4, 2019 at 2:10 PM
  • 55,616 POSTS
This is common when the throttle body needs to be serviced. here is a guide to help us fix the problem:
Also it could have a vacuum leak which can cause the same stalling at idle.
Please run down these guides and diagrams and report back.
Dec 5, 2019 at 4:38 AM
