Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escort
Engine
Symptoms
Revs Up
When putting transmission into forward gears it revs high barely moves
1998 FORD ESCORT
176,987 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JARREDBOY
MEMBER
1 POST
Car goes in reverse. But when you put it in overdrive or D or 1 it revs up top 5,000 rpm and barely moved.
May 12, 2018 at 3:55 AM
Experienced Mechanic
Please check the level of the transmission fluid if okay I would try to service the unit. Here is a guide to show you how:
If this does not work it sounds like the transmission needs a rebuild. Please run down this guide and report back.
Cheers, Ken
May 14, 2018 at 3:42 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
