Will not go pass 2,500 rpm without stuttering
224,000 MILES • 3.5L • V6 • AUTOMATIC
ANDREW FURR
Last week the car stalled on me in the middle of the freeway. I scanned the car and got error codes for the camshaft and crankshaft sensor’s. I replace those today and got the car running. Now my problem is that the car will not go past 2,500 RPM's without stuttering.
Apr 3, 2019 at 7:53 AM
Good afternoon,
Did the codes return?
I would suspect a clogged catalytic converter.
I would drop the front pipe from the exhaust and drive the car and see if it is better.
Apr 3, 2019 at 8:12 AM
ANDREW FURR
I will scan the car as soon as possible. I'll also check the catalytic converter also. Thank you.
Apr 3, 2019 at 9:07 AM
You are welcome.
Always glad to help.
Keep us updated.
Apr 3, 2019 at 9:29 AM
