Will not go over 15 MPH
144,000 MILES • 6 CYL • AUTOMATIC
CARCRY
It was running fine then after being parked for 10 minutes I started the car and the check engine light came on and it won't go over 15 mph.
Nov 13, 2019 at 11:51 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
That means a code is stored in your vehicles computer and therefore the computer has put your car into "limp mode".After the problem is fixed and the code is cleared you car will go back to normal.If you don't have access to a scanner/code reader most auto parts stores have a tool loaner program and can loan you one. Autozone will check your codes for free.Here is a tutorial for you to read about how to check codes:
After having the code(s) read get back to us with the code information and we can properly diagnose this condition.Hope this helps and thanks for using 2CarPros.
Nov 13, 2019 at 5:08 PM
