My car drives but will not go into the next gear. press the gas and it just revs up not going into gear.
Feb 27, 2017 at 9:16 AM
KHLOW2008
✓Experienced Mechanic
No upshifting can be due to various reasons and the first thing to do is to check for trouble codes. A scan tool is required for the process. Check and ensure transmisison fluid level is correct.
Feb 28, 2017 at 12:29 AM
BLACKNGOLD
MEMBER
Fluid level is all good and the code came out to 1698.
Feb 28, 2017 at 2:36 AM
KHLOW2008
This is a trouble code stored in the engine control unit. It indicates the engine is not receiving CCD messages from the transmission control module (TCM). You need to retrieve trouble codes from the TCM . It couls be a fault with the TCM or its wiring circuits.
