Transmission will not go into drive
197,000 MILES • 2WD • AUTOMATIC
LJ MERRITT
I can only shift into reverse. I just idle when I go into any drive position but reverse works fine.
Feb 14, 2019 at 9:31 AM
Good morning,
If you have a good reverse and no forward gears, then it sounds like you have an internal failure inside the transmission. This will require removal and inspection for the failure.
Feb 14, 2019 at 8:46 PM
