Will not go in drive
2003 MITSUBISHI ECLIPSE
300,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
JENJOSHJR
When i try to put it in drive the little line where gear letters are gets stuck I am between neutral and in drive. Car will go in reverse gear and drive though?
Jun 1, 2017 at 7:05 PM
  • 55,214 POSTS
It sounds like the shift cable has gone bad or is frozen inside. I would disconnect it from the transmission and shift the selector by hand to see if that works.
Cheers, Ken
Jun 5, 2017 at 6:00 AM
