Here are more instructions for your car, looks for transmission fluid leaks as well. Check out the images (below). Let us know how it goes.
Image (Click to enlarge)
May 16, 2025 at 5:22 AM
CALVIN WIDEMAN
MEMBER
Okay, thank you. We are going to try this. just now was able to log back in here. I will let you know how it goes. thanks again.
May 17, 2025 at 9:05 PM
✓Experienced Mechanic
No problem, have a good week!
May 18, 2025 at 10:48 AM
CALVIN WIDEMAN
MEMBER
OMGOSH...this is aggravating us to the max. We cannot find any leeks. put it over cardboard for 2 days and nothing on the cardboard...the lady said she had a man to change fluid in it and he only put back 6 quarts...so we checked it and added 1 more gallon..it finally moved in drive after turning it off then starting it back then putting it in drive...it would go about 5 ft n no more till u turned it off back on n in drive...we did this about 8 times n parked it...also it will not move in reverse at all...any more suggestions ?
May 24, 2025 at 3:08 PM
If the transmission was run 4 quarts low then it could have burned it up. Can you check the fluid to see if it smells burnt? Also, I would run the codes to see if any transmission related issues are stored. This guide can help:
