It may have. Overheating can damage parts. The first step would be to run a compression test and a leak down test, just to see if there is any internal damage from the overheating.
Then test for fuel and spark.
If you have good compression in all 4 cylinders then a quick test for fuel and spark is to shoot a bit of carburetor cleaner into the air cleaner and see if the engine fires at all on that. If it does you at least have some spark.
May 26, 2019 at 2:24 PM
