Will not fire
270 MILES • 3.0L • V6 • 4WD • MANUAL
GILLY42
Car stopped all of a sudden.
After having a look I found that the harmonic balancer bolt had come loose.
I have replaced the bolt and have put a new crank angle sensor on.
Car has rule and spark but will not fire.
Can some body please help?
Nov 27, 2019 at 11:44 AM
  • 110,248 POSTS
If you have spark and fuel, it should run. Are you sure nothing was touched with the cam sensors? Do me a favor, see if it starts with starting fluid for a couple seconds. If it does, then we know it is fuel related. Or, check to see if there is an injector pulse. Here is a link that explains how it is done.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let me know what you find. Also, I don't know if there is a difference, but I only have access to the Montero model of this vehicle. In the US, they don't offer a Mitsubishi Challenger. However, they should be very similar. I'll try my best to help.
Nov 28, 2019 at 10:27 AM
