Wont crank over / but throwing a P2111 code
95,000 MILES • 3.6L • 4WD • AUTOMATIC
WADE BOSTIC
Walking to my jeep i hit the remote start 2x on the keyfob. it honked once and didnt do it, so when i got to the vehicle i just hit the unlock button to get in. it didnt work, i had to use the physical key to open the door. got in tried to start it and the power just kept flickering. went to the hood, and in the fuse box could hear what sounded like a relay continuously flickering on/off. disconnected the battery to see if i could reset anything, waited a few minutes and when i plugged it in the relay sound was still flickering. while i was reading the fuse box diagram to see if any fuses sounded like theyd related to remote start or something it stopped and i could hear power travel on to the rest of the engine as i heard the electronics start to turn on, looked inside and radio was turning on and dash was lit no flickering power. tried to start it and it went back to flickering. same relay sound from fuse box area. after few minutes went away again, this time i checked to see if code in dash and there was a P2111 code. tried to clear it and see it would start and it didn't work, went back to flickering. had my wife come and jump it just to ensure that a low battery wasn't causing weird faults, and now i get power with no issues and when i try to start it it just click. but it doesn't go back to power flickering. wait a few minutes to let charge and start it and still just clicks. my confusion is that these issues don't seem to coincide to my knowledge, i could be wrong but wouldn't the engine still attempt to crank and probably run rough if it threw a P2111 code for throttle body. But then why was the power flickering with a continuous relay noise from the fuse box
Nov 18, 2026 at 7:35 PM
MECHTRIX
  • 593 POSTS
The p2111 code indicates that the throttle plate is jammed in a position inside the throttle body this clicking usually happens when this problem accures when the keys turned on the relay turns on and sends power to the ecu wich gets the throttle plate in a default position for starting the engine then the relay shuts off once that happens (wich it is not itjust keeps clicking)might change the relay" the ecu checks all positions and settings and if everything is ready" the engin will be able to start ..but if not ..if somthings out of place or jammed in place it will not start..that said the throttle body might need a replacement but not always you can try using some throttle body cleaner and a soft brush gently on the throttle plate and often times you can get it un jammed and the plate returns to its default position under power for starting and everythings good again ... but keep in mind
If you try all this and nothing works it might just need a new throttle body assembly and or relay. you might find a new aftermarket one on Amazon at a good price ..i think theyre about 100 to 140 dollars and the relays cheap too theyre a pretty strait forward job only 4 bolts and a few plugs basic tools nothing to fancy. Let us know what you learn and we're always here to help
Best of luck "hope this helps
Nov 19, 2026 at 4:08 AM
MECHTRIX
  • 593 POSTS
Side note:
We have all the videos diagams and and procedures availible to us rite here on the website for this "good luck"
Nov 19, 2026 at 4:21 AM
