Engine will not crank over?
94,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
RANDYUNDER53
E250 van won't crank over. Starter good.
Sep 3, 2023 at 6:31 AM
  • 110,248 POSTS
In most cases, a crank no start condition is either related to a fuel issue or an ignition-related issue.
Here is what I need you to do: See if it will start if you use starting fluid. If it does and then stalls, we know it's a fuel-related issue. If there is no change, I need you to check for spark to the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
joe
Sep 3, 2023 at 3:58 PM
