Will not crank on slight incline
178,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DUBREED36
My car will not start on a slight incline but when level doubt it cranks perfectly fine. it turns over but it will not start, but once it starts runs perfect. that's only when I'm on flat surface. I'm not sure what to do. I have been told fuel level sensor. I have been told a fuel pump. I have been told a fuel sensor. I don't know.
Mar 22, 2020 at 1:03 AM
Good afternoon,
This sounds like a baffle could be broken in the fuel tank and fuel is not at the pick up for the fuel pump. Someone would have to remove the fuel pump and look inside the tank and inspect for a baffle being broken. The baffles are there to prevent this exact issue.
Mar 22, 2020 at 1:09 AM
Just so I am clear, when you are on an incline the engine cranks but doesn't start. Then when on flat ground it starts normally? Does this do it no matter how much fuel is in the tank? Meaning does it do it with a full tank of fuel?
The only thing that knows it is on an incline is a fluid so if it does it with a full tank then I would suspect the pump itself.
Just clarify this and we can go from there.
Mar 22, 2020 at 1:11 AM
DUBREED36
It turns over but will not start it act like it's out of gas but the last time I noticed I had maybe one fourth of a tank. but as soon as I rolled it on level ground it cranks right up with no problem. also the second thing that it is doing when I go to put gas in it it keeps stopping like it's full.
Mar 22, 2020 at 1:15 AM
You need to have someone check the tank as I suggested.
Mar 22, 2020 at 1:18 AM
DUBREED36
Okay, thanks.
Mar 22, 2020 at 1:20 AM
You are welcome.
