Engine will not crank, anti-theft
300,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JCPHILLIPS21
  • 12 POSTS
I was working on truck had it idling in the yard then all of a sudden it shut off. now every time I put key in theft flashes rapid for minute then gives code 16. I tried both the main key and the spare key both coded to that truck doesn't work truck just turns over but no start.
Mar 18, 2022 at 7:56 AM
  • 55,797 POSTS
This code comes up when the cluster is not working when you turn the key on does the cluster work. You could have popped a fuse which could cause this issue. Let's start with the easy stuff first. These guides can help also I have included the fuse locations:
and
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 19, 2022 at 9:34 AM
JCPHILLIPS21
  • 12 POSTS
Yes, fuse is good, and I tried the little tricks to bypass the pats. nothing worked.
Mar 19, 2022 at 11:38 AM
JCPHILLIPS21
  • 12 POSTS
This first started when something was overcharging my battery, and someone reseated the cable and I guess instead of overcharging the battery it sent all those volts to everything else. someone said that could have damaged the computer could it?
Mar 19, 2022 at 11:39 AM
  • 55,797 POSTS
Yep, that can do it, have you run a CAN scan on it? Here is the link:
Mar 19, 2022 at 11:53 AM
JCPHILLIPS21
  • 12 POSTS
Tool the computer out of its casing and there's a burn spot assuming that's the problem. Do I need the exact same computer for it to work in my truck? And what could be causing the overcharging issue? I've already replaced the voltage regulator.
Mar 19, 2022 at 4:43 PM
  • 55,797 POSTS
As you can see from these wiring diagrams the cluster has a voltage gauge that interrupts the charging system so if the cluster is bad, it will cause charging issues. Check out the diagrams (below). Please let us know what happens.
Mar 21, 2022 at 3:26 AM
JCPHILLIPS21
  • 12 POSTS
Thanks I'll look into that.. Could this be the cause ?
Mar 21, 2022 at 7:38 AM
  • 55,797 POSTS
Yep, it looks like you may have found the issue, you can fix that by soldering over the break.
Mar 21, 2022 at 8:18 AM
JCPHILLIPS21
  • 12 POSTS
Really all I have to do is solder over where the strips are broken. to fix the overcharge issue so I need to check all of those wires in that ground for a naked wire.
Mar 21, 2022 at 8:39 AM
JCPHILLIPS21
  • 12 POSTS
It didn't fix it still gives me theft code 16.
Mar 21, 2022 at 11:05 AM
  • 55,797 POSTS
Does the cluster work now? Also did you clear the codes? This guide should help:
Mar 21, 2022 at 11:59 AM
JCPHILLIPS21
  • 12 POSTS
Yes, everything on the cluster works other than mileage is all dashes. No, I haven't cleared the codes, I'll try that.
Mar 21, 2022 at 1:51 PM
  • 55,797 POSTS
Okay, please let me know.
Mar 24, 2022 at 2:53 AM
