Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
1500
Engine
Symptoms
Not Running
Not starting after engine has warmed up
1988 CHEVROLET 1500
75,000 MILES
CLARKPLC
MEMBER
will not start after the engine is warmed up.
Feb 19, 2018 at 3:17 AM
Experienced Mechanic
Good afternoon
When it will not start, did you check for spark or fuel???
Feb 19, 2018 at 5:27 AM
CLARKPLC
MEMBER
yes it is getting fuel and spark.
Feb 19, 2018 at 8:33 AM
Did you check compression?
Feb 19, 2018 at 1:26 PM
CLARKPLC
MEMBER
yes, compression is fine. it will start and run when is cold but when you turn it off it will not start back up.
Feb 20, 2018 at 12:59 AM
Okay, when it stops, check for spark and fuel. one of them will be missing.
Feb 20, 2018 at 1:02 AM
CLARKPLC
MEMBER
both are there. it fires and gets fuel, you can see the fuel spraying into the throttle body.
Feb 20, 2018 at 1:12 AM
CLARKPLC
MEMBER
do you think maybe the coil is going bad?
Feb 20, 2018 at 1:15 AM
it is possible but needs to be confirmed when the issue happens.
Feb 20, 2018 at 2:23 AM
CLARKPLC
MEMBER
it is the module by the throttle body, i ask a mechanic.
Feb 20, 2018 at 6:43 AM
that is the ESC module. that will not cause it to not start or cut out.
Feb 20, 2018 at 6:49 AM
CLARKPLC
MEMBER
the pickup module in the distributer was the cause
Feb 21, 2018 at 7:55 AM
Good find. very common failure for no spark.
Feb 21, 2018 at 5:19 PM
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
